Unstable braking at high speeds
Took the car for a real aspirated drive since purchasing the 172 Cup a few weeks back.
Notices coming down from high speeds while applying brakes at medium to hard pressure that the car is quite skittish, moving from left to right (snaking at rear). Am I thinking that this is due the springs or uneven brake wear maybe, or is this a characteristic of this car?
I would not say its due to the car not having ABS
BTW cracking little car :evil:
Nothing to do with ABS. Could just be the road surface however...
Check the rear dampers for leaks/damage etc. Quite a common fault on Clios.
Mine is very similar to yours, think its a bit of a charateristic of smaller hatch backs, may be worth checking your rear brakes tho and making sure the sliders on the calipers are free and not binding otherwise it may be braking harder on one corner than the other.
Thanks Andy, I can def feel the car bitting on one side, almost like it snaps to the left after initial bite.
Will check it out, Im looking at changing all the brake discs anyway, however just interested to know it "was the norm" or not. Thanks for your help guys.
I'd bank on a knackered shock personally, I've had similar trouble in the past. Oh and if it is a shock dont take the cheap route and only replace one like i did, your opposite will go soon after!
