well, having swapped the front and rear tyres over this evening it appears the problem has gone! car drove completely differently, and in a good way, didn't pull left or right, except for the very very slight pull to the left you get as standard on some roads. some times it still felt a little harder to steer left, but only minutely, maybe because i'm looking for it though. braking approaching junctions with a light grip on the wheel it braked straight and true. it's been 7 years since i last owned a performance car (integra that i sold in 2003) which makes it 8 years since i've had this much fun and felt this confident throwing my car into the corners. still got a slight knock sometimes when hitting uneven bits in the road which i think is a dodgy tie rod (i've got a new one to go on) but apart from that it's looking rosy (touch wood). the real test will be on my monday morning run to work when i traverse the same roads that usually gives me problems. fronts are pzero neros, rears are T1r's. very tempted to get non-directional tyres now
two things i need help with though:
i noticed the left rear has noticeable wear on the outside shoulder, more so than the right rear. nothings bent (recent hunter alignment confirmed everything within limits). suggestions?
you know when you have a worn front joint and you can feel every imperfection through the steering wheel, i get this on the rear. are there bushes on the rear, and would these generally need replacing? rear bearings and shocks are newish.
thanks all :cheers:
