upgraded brake discs
Car  Fabia VRS
my current brake discs are running low but i dont know whether to go for upgraded ones, possibly brembo?
i only have a 1.2 so im not sure if there would be much point
thanks
jordon
If i had my 1.2 still id go for Brembo HC discs and Ferodo premier pads from Halfords.
Discs from online, and pads like i say from Halfords, although standard discs and pads are absolutely fine tbh, just depends if you think you need the upgrade.
Standard 1.2 brakes are way over-rated for the car so standard set up should be fine
thanks
jordon
Standard disks and pads are more than enought if your having problems with them then sort the faulty brakes out.
i dont think theyre faulty, they squeak. so im not sure if its discs or pads so was thinking of changing both.
