Upgrading my Macbook
Car  6/468 17poo
I have no knowledge of how to do this and what to do, I have an old alloy Macbook probably 2008 model, its not a pro but has the same case as the Pros these days. This is the spec: Model Name: MacBook Model Identifier: MacBook5,1 Processor Name: Intel Core 2 Duo Processor Speed: 2 GHz Number Of Processors: 1 Total Number Of Cores: 2 L2 Cache: 3 MB Memory: 2 GB Bus Speed: 1.07 GHz Whats the best thing to upgrade to make it faster? The HD is only 160gb i think so that definitely needs to be upgraded! If anyone has any knowledge of how, please shed some light or links! Cheers, Ryan
You could double the memory to 4GB, think that's the max but could be wrong. And a new HDD, that's about it.
It aint hard to change out the RAM. Crucial are the best/cheapest and have a computer scanner so that you cant order the wrong stuff (Basically run the scanner and it'll tell you what you can have).
The older RAM does seem to be more expensive than the new stuff but it aint that much more. Should speed it up considerably.
Also, as opposed to sticking a replacement HDD in, would you not consider going down the SSD route? We have SSD in our Air and iMac and everything is instant.
SSD is expensive though, hybrid might be a better compromise if he's after a big HDD
(Sorry in advance for something of a thread hijack, but it's a related point with no need for a new thread of its own!)
I'm thinking of ways to boost my 2009 MacBook Pro (2.26 GHz Dual Core) and have already decided to upgrade the RAM (will I see much difference between going for 8GB over 4GB? Alot of conflicting reports - I do mainly design work in illustrator, indesign as well as photoshop work and video editing). I'm also interested in going hybrid, with a smaller SSD to put all my applications on so they load quicker, but how do I go about this? Any links? It'd be straight forward enough with a desktop Windows PC, but a laptop Mac seems a lot tighter and more locked down!
EDIT: Thoughts on this?
Whats the best 500gb hd to replace my existing drive? ssd's are too expensive
Most new hard drives are expensive at the moment due to the floods in Taiwan. Any hard drive will do, I have a used but working Seagate Momentum 320gb 5400rpm drive and 2 x 2gb Macbook pro ram spare if its any use? £25 posted for the lot?
This is true, I'm waiting for prices to drop atm as I'm after a couple of 2TB drives.
If your getting an SSD purely for applications (presume this is going where the superdrive currently lives, think Tom has done this) then just use your current HDD for your data.
If your just wanting to stick to one drive, the hybrid like you linked to is the sort of thing to go for.
As for RAM, max out if your computer supports it.
Just plugged in my new RAM, up to 4gb now and it really shows running Traktor and Albeton, best £20 ive spent in a long time!
Need to make a decision on a bigger HD now tho! suggestions please...
