URGENT: Drive Boot? Leaking?
The rubber gator that sits just behind the wheel hub on the front wheels, what is it called? And I imagine that it should not be leaking thick greyish grease? Will it be ok to drive 8 miles to a garage tommorow?
Thanks Mat.
It the constant velocity joint gaiter, no it shouldnt be leaking, clip has probably split, yes its fine to drive it the 8 miles to the garage!
Driveshaft gaitor. Shouldn't be leaking, more than likely your clip that holds it onto the CV has come off
8 Miles will be fine no problem
Theres a joint inside it that moves with the hub, keeps it lubricated so it doesn't go Bang bang bang up the street.
