URGENT HELP NEEDED
  Civic Type R EK9
Driving along and my range on trip comp started flashing pulled over switched car off and bk on and now no speedo and engine management light is on????
i did a check and it comes up with t--h??
also im going on a long drive and need a speedo if i disconnect battery any luck you think?
  BMW Z4 3.0i
No idea, but as long as the red "stop" isn't illuminated, I'd say you're safe to drive to a dealers to get it looked at. Just be cautious through speed camers!
  Civic Type R EK9
just disconnected headunit and it works again but still got ecu light on
is there away around this interferring in or shall i go get my money back?
  BMW Z4 3.0i
Might have been something you've done while connecting it up.
But tbh I can't really see how they're related and imagine it's just co-incidence. If the fault codes have come up then Renault should be able to tell you straight away what's broken.
  Civic Type R EK9
same fault codes as always tho its a lg headunit
like i said i completly disconnected it and the speedo worked again just engine management light still on
Da
  Less
Try re-setting the fault codes to see if it clears the fault. If it does then the ECU light should go out. As for the speedo not working I think this is due to the remote output of th LG unit but I'm not 100% sure.
  Civic Type R EK9
ok do you know anyone i can call now to go around cutting remote wire etc as i need to go out asap!!! how do i reset fault codes?
Da
  Less
Get to the fault codes display, then press your reset button that is mounted in the speedo. It also resets your trip readings.
Sorry I don't know anyone to call.
  Civic Type R EK9
yeh ok ive done that but still management light ive drove car with and without radio plugged in and when it aint plugged in it works and when it is it doesnt so does anyone know a way around this???
and by disconnecting batt will it turn eng man light off
lemonnobby
put the standard head unit back in, try disconnecting the battery to get rid of engine management light to go out.
