URGENT: OE Speaker Wiring Info Needed
  Skoda Fabia vRS
which is + and which is -
on the pass side ive got purple and yellow (ish)
on the drivers side ive got orange and yellow (ish)
MaLicE
Honorary Member
  Lazy v8
erm.... purple is pos i think, doesnt matter which way u connect them, the speakers will be out of sync if they are wrong.... just trial and error.
  Skoda Fabia vRS
well thats what i thought but ive tried them both ways on a speaker and when i choose the balance left and right it works both ways
BRUN, the ISO is one i got from Halfords (as the original was chopped off) so should have the connections stamped on the cable or, at worst, you get them off the Smartlead/Autolead website. Once youll have that youll be able to match them against a clio wiring diagram in Haynes etc if you dont think theyre write or alternatively speak to someone else with a 16v/clio.
Hope this helps
  Skoda Fabia vRS
managed to sort it in the end by figuring out that the little tweeters have + marks on them so figured out the correct wiring arrangement from that
  Skoda Fabia vRS
i think on the pass side purple was + and on the other side the pale yellowish wire was + but dont quote me on that as i cant quite remember
