Where is the hole used to lock the crank in position located on a 16v clio (j reg), really need help asap as we have the engine up in the air t the moment and are stumped .
Is there anything else we should look out for when doing this
it just above the sump on the engine block(@the front) on the right hand side(near the gearbox). you have to remove a blanking bung(13m or inverted torx)
