the original Renault fit LED flashes on the instrument panel, on both our diesel and the V6 - but then the Cup had one next to the gearstick as well. The diesel only has one on the instrument panel cos it doesnt have an alarm I guess.
so the answer is - there is only one on the instrument panel on the V6 !
yeah the one on the speedo clocks is just the immobiliser, the cat one alarm LED which all UK renaultsports and V6s have is seperate, its not on the gear lever mount I take it?
the plastic is a right tw*t to drill on the v6 you have use a few sizes if you just stick a 10mm through it.it pulls the plastic up the drill bit oopps time for a new centre console
liam
if you take your cup holders and ash tray out you can push the led back up
