I have mate yeah. The fit isn't fantastic tbh, from some angles it looks like it's coming off the car as its not aligned but some are much better. I think I got unlucky.
@optical has one fitted too. Other than that they're decent. You also might need to file away a bit of your tailgate where the bolts line up. Not by much though. Think I've got some pics of it fitting in my thread. It will be around jan 2015
My opinion is that it looks brilliant, is a bit of a pain to fit and get it to line up right. As @dann2707 says you do need to dremel or file a bit of the boot lid to get the bolts to line up.
Also my tip would be to use body filler on the washer spray hole.
