I know from other posts that the general concensus is simply to do away with air intake system altogether but does anyone have information on just how it is supposed to work. From what I can see there is a vaccuum connection from next to throttle body that runs to the valve.
Logic would seem to indicate that under high vac loadings (ie full throttle) this would open the valve and allow more air in, however I notice that the valve is actually in the open position when the engine is off and under no vac!. Surely it doesnt close at full throttle, or is it controlled by the ECU.
Ill probably follow convention and just remove it, but I am curious to find out just how it is supposed to work
regards
