iirc, you can run a volvo/rsi alternator bracket to rid of the pas. A guy on here with a 172 engined mk1 used this and has a manual rack.
why not use the elctric rack found in the diesel mk2 ph1's and take a reading from the abs unit.... if your keeping abs.... which i dont think you are.
wayne uses a renault safrane alternator and bracket iirc but i cant find one of the bleeders
he has also said a volvo 440 alternator and bracket which im looking at now, but as per my other post in here they have 2 different types of bracketa and i dont know which one i need!!
Ben if your keeping the ABs as we reconed you should do then just get one of the high power 80AMP (from memory as fited to dci and 1.4/1.6) electric rack and use that the system stand alone just need to give it power and tell it the speed your doing which is easy with the abs syetm as it has a feed out.
