Valver PAS Question
Car  Clio 16v, Polo SDi, M3
I have just searched the forums for a definitive answer as to removing PAS from a valver and fitting a manual rack but to no avail, yes plenty of post, no definitive answers. :S
AFAIK I'd need a manual rack, manual column and some sort of bracket for the alternator.
Is this pretty much it?
yep, manual column (longer than pas column), manual rack, you will prob need to get some new track rod ends aswell (my pas ones were female, whereas the manual ones are male), then sort out bracket for aux belt (im pretty sure mine came off a renault safrane!) and then you will need a shorter aux belt.
As yes, I knew I'd forgotten something (track rod ends).
Thanks again.
