Valver sunroof Pee's!!
Car  Rover 620ti, MK1 Valver
my electric valver sunroof leaks from above the motor.. bigstyle!
the water comes peeing out of the side of metal bracket the motor is bolted to.
i know this is common.. where exactly does the water get in? and whats the best way to seal it without losing the sunroof?
cheers :D
ive heard selling the renault shite works a treat.
serious, can you not put some sort of sealent aront the rim of the sunroof.
Basically take all the bolts off the sunroof. Take headcloth down and unbolt everything then take the sunroof out, then clean it etc. Then seal it and bolt everything down again.
myns leaking real bad too....think this is going to have to be an afternoon jobby one of the days next week...
same happened to mine (but non valver)
i took the entire sunroof out, dried it, cleaned it, resealed the lot. it started leaking again about a year later :(
