valver to williams conversion
V
valver pete
Thinking about putting a williams lump into the valver, anyone with advice, tips, knowledge, what to do/not to do etc etc about doing this would be greatly apreciated.
  2005 Nissan Navara
straight swap...
only "issue" is if your car is ph1 and the engine is ph2 (or vice versa), the multiplug for the engine loom has a different pin layout----meaning the fuel pump wont be ecu controlled. SO u can either swap looms (plenty available, check www.williamsclio.co.uk) or ammend the plug wiring. like i say, this isnt much of an issue....its VERY easy.
  Looking for a ph-quick...
Just use the 2ltr bottom end from the willy, will fit straight on the 16v head, u will need to use the Willy ECU thoug
V
valver pete
^^looks like very nice work. can you run the valver gearbox with them or swap that aswell?
  2005 Nissan Navara
u can run a valver box yes. if u buy an f7r with a box ur better of fitting that tho...
V
valver pete
what sort of power would you be looking at getting from that engine? To do a swap could you provide the engine or would i have to source one?
  2005 Nissan Navara
that engine power wise is pretty std, so around 150bhp. with some of my headwork, and cams, theres no reason why we couldnt see 200bhp+ on the std inlet manifold.
i can fit one that you supply, or one i supply.
