vibration?
Car  Clio 172 Rep (SOLD)
hi guys, over the last week i have developed a weird vibration. it sounds like a cross between the brake pads being worn and the wheel bearing going. however both have been checked and all bearings are ok with no play in them whatsoever. it stops if i turn left and gets worse if it turn right. it also gets bad under breaking. the discs are not warped. i have been to a garage and they cant seem to know what it is. any ideas? thanks
sounds very much like a bearing if you get it when turning 1 way, u sure they are ok? how did u check them?
i have replaced the bearing on the front right wheel i can feel it through my right foot. any chance it could be somewhere else with it sounding and feeling like my front right wheel bearing?
It is the wheel bolts me thinks.
Give them a good tighten up.
It will the be the left hand front wheel I reckon.
Sam
thanks, done everything i can think of. Everything is tightened. still doing it. i think it must be something simple but i can think of anything else. i have jacke dup the entire car and there is no play in any of the wheels, bearings, no rubbing.
any other ideas greatly appreciated. thanks
