Vinyl wrapping recommendations South East
Car  Arctic 182
A relative has got a Fiat 500 with a sun roof which has a panel between the sun roof and the front windscreen. The panel is vinyl wrapped but the vinyl has started peeling.
We've been on to Fiat about it, and they've said that the panel would need to be removed, which requires the front windscreen to be removed - at a stupid cost.
However, a few local places have said that it is possible to just rewrap the panel without removing it. Is anyone able to recommend anywhere in particular in the South East area?
Is it a fairly flat panel? If so, just do it yourself mate. Until you throw in complex curves, then wrapping isn't difficult at all
Yeah it's flat from edge to edge. I have thought about that, just thought I'd see if there was anyone on here who's an expert at it and would be happy to help out first.
I've not used these myself, but have heard good things about http://www.dubcustoms.co.uk/ in Basildon.
I’ve been after having a replacement bonnet wrapped for a little while now, and I approached two companies around here:
KJ Wraps in Newbury - http://www.kjwraps.co.uk/
Car Customs in Basingstoke - https://www.car-customs.co.uk/
I went with Car Customs in the end as they were a little cheaper and closer to home.
Perfect - I've contacted all three. Cheers
