Viper help!
  182 Trophy No. 223
Hey guys, simple question i cant find any threads on...
Do i need to remove this tube that runds down to teh underside of the car and/or does or has anyone left it in and just fitted teh viper kit over the top??
benn
the caf runs down there leave it on m8 otherwise u suck hot air;)
wheres u caf pipe that comes wid the viper , put that on
  182 Trophy No. 223
so what would be the best way to seal it?? Just but teh cable tie around the two tubed thus making a seal??
  182 Trophy No. 223
cos at the moment, it isnt consistent, so the fact warm air is going in, would be why!
  182 Trophy No. 223
Forgive my ameturness!
so insert the existing intake into the viper one, and then seal with with a jubilee clip - as far down the intake as possible (away from engine) or the other way?
  Lionel Richie
take off passenger wheel, pull arch liner out of the way, remove all the crap behind it (leave the horn in!)
run feed pipe down where all the crap was, you now have 2 options, feed to the front bumper lower grille, or fog light
  182 Trophy No. 223
so not using the exisiting lower box at all??:S
  Lionel Richie
2 x 10mm bolts under each arch (remove arch liners)
2 under the front spoiller (about 12inch back)
a sharp tug, and it's off
  182 Trophy No. 223
excellent, will get to it, one other thing.
Conect the viper intake to the existing box? and if not, how do you attach it to the front grille! Thanks
  Lionel Richie
no, remove all of the OE crap and put it in in the bin!
remove -
complete airbox (2 halfs)
all oe feed pipes
stupid valve under arch liner (block off vaccum pipe)
ho long is ur caf ............... u might need to order an extension 1 to feed to the lower grill , :cool:
  182 Trophy No. 223
not long enough! Do you guys take the air feed down fast the headlight over the wiring loom thought that gap??
there isnt enought space so i've just put the over the existing tube for now....
Saying that, when pushing her, in 2nd, it doesnt really kick in until5.5/6k revs.... i think this is because there is air being pulled in from thsi connection not being seal enough? After that she's just awesome!
Bennigin said:
so what was the total length you needed of duct to feed it right through and up??
where did u buy ur viper from , tell them to order extension hose , pipercross will give it free as long as u proove purchase .;)
  182 Trophy No. 223
Okkkkkkk!
I had no joy removing the bumper sunday morning, i gave it a good tug from both sides, and no movement, any help??
Bennigin said:
Okkkkkkk!
I had no joy removing the bumper sunday morning, i gave it a good tug from bother side, and no movement, any help??
me had the garage fit my cold air feed from underneath , had it up on the ramps removing the undercover panel ..........:star:
  Clio 172 mk2
remove -
all oe feed pipes
The 'stupid valve' changes the length of the intakes improving midrange torque...best left in place
ant
  yep.
Bennigin said:
ok, reallllly pulling on it....i couldsee the bumper flexing!!! :S
well if its not coming off you need to pull harder!! :approve:
it does go with some effort!
ant
  yep.
ripped it out - didn't notice any difference whatsoever.
  182 Trophy No. 223
wey!!!!! Spent a fair while making teh intake secure, just need to but into teh plastic in attached to teh arch for the duct tube will go through, and hey presto!!
  182 Trophy No. 223
Halfrauds say pipercross dont make a 70mm duct tube... and is there aq special connection to join teh two pipes??
Also, am i just able to buy the duct in a 1.5meter length!
thanks fellas
thanks fellas
bollox...........dont join 2 pipes together .
ask them wot the size is for the viper then ??:mad: ask for 1 pipe only :star: thought u had urs from k-tec
