call the fault line, we had problems and every time we called we got put through to an engineer they re-funded the call completely...
DSL vs Cable - Real-World Speed
In practice, cable's speed advantage over DSL is much less than the theoretical numbers suggest. Why?
- Cable modem services can slow down significantly if many people in your neighborhood access the Internet simultaenously.
- Both cable modem and DSL performance vary from one minute to the next depending on the pattern of use and traffic congestion on the Internet.
- DSL and cable Internet providers often implement so-called "speed caps" that limit the bandwidth of their services.
- Some home networks cannot match the speed of the Internet connection, lowering your performance
ive got a 20mb line and its always maintained stable speeds of around 19,500mbps downtime.
I'm sure it isn't quite that simple Russ is it? Contention ratios come into play on ADSL and cable don't they?
You're perfectly correct and at the same time wrong. VM have a contention ratio of 50:1, when I last checked. "Some" DSL providers have a contention ratio of 33:1 and 20:1. One I know of, and have worked alongside, have a contention ratio of close to, if not, 1:1.
I would elaborate but they're in the process of "restructuring" having been taken over by a mobile phone company.
In short Roy you are indeed correct that contention affects all forms of provider but some more than others.
I could be wrong but AFAIK both can be affected by heavy traffic. On a plus note, I don't think cable is affected by distance (although again I may be wrong) so none of this 'up to' 8mb. My connection seems to vary between 12mb and 18mb. Pretty quick TBH. That's my expereince anyway
Erm because unless you're downloading the queens funeral in 1080p, Bit Torrent is about a good indication of line speed, as me wondering why I have a 7 1/4 erection every morning.
Unless you're the next Albert Einstein I very much doubt it...
You misread my answer Roy.
I said ive noticed a DROP in line speed whilst ive been using Bit Torrent, ie: at the peak times i get a lower download speed than at 1am say.
tbh Roy i never get much less than that other than at peak times as i said.
i dont use Bit Torrent as a guide at all just to clear that up.
Ive had a 20 meg Virgin Cable line at my house for about 3 months and never had any problems with speeds.
I suppose it depends where you live and the ISP your with.
ive not monitored my line to the extent both you Roy and Griff have.
However from personal experience every time ive tested it on a few different speed tests its always been in the 19k kbps bracket.
a 50mg line seems silly to me?
I know you can get higher speed connections through Satelite but why would you want to do that i dont know.
I wanted a high speed line so i can get a good ping rate on COD3 and to be able to download films etc without waiting weeks.
In the real world rendering web pages a 2mg line would suffice.
im with Virgin,
its because its cable and most people log on at that time, the bandwidth is shared on a cable connection unlike ADSL.
