Vista + UAC + Downloads ??? Help
  A well built VW
Running Vista and recently switched off UAC
Went to download MSN Messenger tonight and can't - goes through all the motion set location to d/l to but nothing ever happens decided to try and download something else and same scenario
Do you think UAC switched off is causing this - Ive forgotten how to switch the bloody annoying thing back on and really dont want it back unless i absolutely have to
Many thanks
  A well built VW
cheers chris been searching but nothing so far - UAC now switched back on but nothing has changed
tried using torrentz as the software is free so ok to do ;) but its the same
AVG will not run - not looking goood
Cheers harper but i have tried around 10 different sites to d/l and none work think its my computer
  A Beautiful R32
hmm
I have both AVG free and msn messenger running with vista and no problems...
I know its a daft question but have you tried installing/running them as an administrator?
They should both work ok...
Oh and turning UAC doesn't do anything other than leave some annoying mesages sometimes.
Plus make sure that your computer is allowing them to access the internet (Control Panel --> Network and Internet --> Allow a program through a windows firewall).
Hope that helps.
If not try this:
http://www.howtogeek.com/howto/windows-vista/
  A well built VW
cheers all fixed now (fingers crossed) reset i.e. and system restore followed up by removing and re-installing AVG and all is good
