w reg 172 immboliser problem
  106 rallye
Can you unlock a 172 ecu so you dont need to use the immboliser?
As the car is having problems on start up and causing loads of problems.
In theory yep some cars have had trouble and cannot do it as such though.
Fix the problem though if the imobiliser light not going out then sort it out don't bypass it.
If the lights not going out you need a new decoder ring or check the wires for a fault.
