wanting to lower my 182 but...
Car  RB 182
hi all i want to lower my 182 but only by like 30mm , reason being only 30mm is because i have 17" oz superturismo alloys on and not sure if i lower it any more it would rub against the arches? also do any of you think at 30mm it might still rub, thanks again in advance for your answers :D
Get rid of the 17's pal, either 15's or 16's then get eibach sportlines. Leaves the car at a nice height and no rub. 17's don't look right on small cars.
what tyres are you on? (dimensions)
195/40 r 17 for example are smaller in diameter than 205/45 r16 so I don't see why they should rub on the arches
get some coilovers lower as much as you want then, i'll have some for sale soon ;)
What offset are the Oz wheels as that will ultimately decide how low you can go?
lau i had my 1.2 lowered with them on 40mm on apex springs no rubbing at all but ofc wasnt a sport.
tyres are 205/40/17
Personally, if you like the wheels, I'd sell and get 15"s or 16"s in the same style.
I can't see any reason why you'd want 17"s on a clio. They look awful, add unnecessary weight and tyres cost a hell of a lot more.
How much do you want to spend?
Sportlines would be a nice littel drop and you'll keep some degree of comfort but essentially, whatever you do, you're a inch further from the ground before you even start.
