Quote: Originally posted by brazo on 25 March 2005
IIRC Paint thickness is measured in thousands of an inch and typically paint including the clearcoat is around 20 -30 thousands of an inch with the hard clearcoat forming approx 8 thousands of an inch, wet snading with a 1200 grit paper will generally remove 1-2 thousands of an inch per gentle pass, tests were done poilishing paint 30 times in a month with an abrasive polish with no real reduction in clearcoat thickness.
You would therefore literally have to polish your paint every day!
Saying that Renault paint is ony two thousands of an inch thick and can be fully removed after 3 polishes
he he, a bit more technical than my answer
, but just the same none the less
ps brazo did you get your order yet
