put denture tablets in the bottle let them soak for a while..put a hosepipe in let it run for 5 minutes...if that doesn't work,your pumps are knackered ,the rubber inside expands over time...Renault wanted £50 per pump ,i bought 2 from euro parts for £20 (discount code..)Part 488545050..(Clio 182) both pumps are the same ..i used a windscreen wiper removal tool you'll definitely need one...Pretty sure my washer bottle is full of gunk thats blocking up the pumps, anyone had success using anything to clean it out without actually removing the thing?
The Europart pumps on mine are not like the genuine ones..sometimes they have a debate on whether to send water to the right screen..I did save £80 so I don't mind waiting a few seconds...they're getting better..put denture tablets in the bottle let them soak for a while..put a hosepipe in let it run for 5 minutes...if that doesn't work,your pumps are knackered ,the rubber inside expands over time...Renault wanted £50 per pump ,i bought 2 from euro parts for £20 (discount code..)Part 488545050..(Clio 182) both pumps are the same ..i used a windscreen wiper removal tool you'll definitely need one...
I cleaned mine out with a dishwasher tablet
Nah, just remove it as it's easier and the time spent messing about with some elaborate cleaning method you could have removed it, cleaned it, put it back and had a brew😂
Wear gloves😂Then admire all the cuts on your hands from trying to get the fucker out!!
Wear gloves😂
