Washer bottle empty!
Car  1.2 clio
Everytime I top up my washer bottle water was gushing out of the passenger wheel arch so I investigated and found out where the leak was coming from its coming from where the pump goes in to the bottle. My question is... Is there ment to be a seal or some sort of gasket between the pump and bottle or is it plastic to plastic pump to bottle?
There is a seal that the pumps push into. but the bottle has probably got a slight crack at the bottom, where the seal meets the bottle. Had it on mine.
Take it out, stick some sealant around the rubber grommets. Let it dry, test seals again before refitting. Job done!
40 min job max.
