Washer bottle leak
Car  Westfield, 182, 200
I have a leak from my washer fluid bottle somewhere. It loses about 100ml a day.
Unfortunately, as it's so damp, I can't pressurise the bottle to see where it's leaking from. I've had the bottle out (what a PITA) and it looks dry.
Any common areas where they leak?
Ian.
Are you sure its not your headlamp washers if you have them? Could be a split pipe?
Headlamp washers, are common mines just done that this last week so I've disconnected them, it can also be the seal where the pumps (x2) plugs into the side of the washer bottle..have a look for a drip :S
Finally found it!!
It was the headlamp washers as was pointed out. The off side one has a split in it and is dribbling!
Will phone Renault for a price tomorrow.
Cheers, Ian.
