right my washer pump isint working
ive taking it out and run 2 wires 2 it off a battery and it pump so im gessing its the relay as ive checked all th fuses
were is the window washer pump relay???? and which 1s is it?
Umm pretty sure there isn't a 'relay' for the pump on its own only thing slightly related would be the intermittent wiper relay but that wouldn't affect it. Check the stalk. plug a testing light where the pump should be see if it lights up
I have the same problem with my washer pump, it worked in August then stopped, replace in late August, worked for a bit then its stopped. I wanna know what else the washer pump goes to in the chain as its pissing me off now. Anyone?
