USE OF THE CLAY BAR
What is a clay bar, and what can it be used for
Clay isn't a polish or a compound, it is a surface preparation bar that smoothes the paint and removes contaminants, Clay is not a replacement for polishing.  It's a tool for quickly and easily removing surface contamination
A clay bar is as its name suggests a bar of clay, and is usually used in conjunction with some form of lubricant (or even normal car shampoo), and basically it is used on your cars paintwork/wheels/ and even glass, to remove surface contaminants such as tree sap, tar specks, brake dust etc.
The clay is used after washing the car and before applying waxes etc.
Clay is also very effective on paint over-spray.
Do you need to use a clay bar?
No matter how much you wash and wax your car this is not enough alone to remove certain contaminants, in fact waxing over such contaminants will only seal them onto your paint.
To check if you need to clay simply was your car and dry now simply run your finger- tips across the paint surfaces, which should feel as smooth as glass, if it doesn't then your paint is being attacked by contaminants, Removing these surface contaminants (tar, acid rain spots, bug residue, paint over-spray, brake dust, hard water spots, etc.) will improve both the look and health of your car's paint.
Using clay
Using clay is easy but do follow the manufacturers instructions, if you don't you could create a mess or mark your paint.
Firstly ensure that you car is thoroughly washed and dried, as with all car cleaning try to do it in the shade, and apply to a small area at a time. Then roll your clay into ball, this warms it up and makes it more usable, then mould it into a flat surface, you then spray a small amount of the lubricant onto the panel, and then rub the clay in back and forward motion using light/medium pressure, if it becomes hard to rub then you need to use more lubricant (this is because clay is quite sticky). When you have made a few passes rub your hand over the area and it should be smooth, if it isn't then you just follow the same process again until the area becomes glass smooth, when smooth remove all the residue with a micro fibre towel (a soft cotton towel will suffice also).
When you have completed the whole car it is advisable to wash the car down to remove the lubricant, you car is now ready for glazing/sealing/waxing, etc.
Tip, when you can no longer fold the clay into a clean surface you can use it for claying your glass or even your alloys, it surprising how much dirt you can remove from your cars glass, and likewise clay is perfect for removing brake dust from your alloys (Clay is not recommended on wheels that do not have a factory clear coat or powder coat finish).
Clay safety
1. Clay does have a mild cutting action so be careful in its use.
2. If you drop you clay bar dispose of it, as dirt will engrain itself into the clay, and this will of course scratch your paint.
3. Fold your clay regularly and check the clay often, if you find raised bits remove them with you nails
4. Always Read the manufacturers' instructions.
POLISHING
The term polish and wax are often misunderstood, mixed up and used in place of each other.  It does not help when a lot of products on the market blur the lines between a polish and a wax.  A polish is a process that should be undertaken infrequently and is simply used to remove minor blemishes, surface scratches and swirl marks.  Once you have polished your cars paintwork it will feel smooth.  Polishing a car will remove under the surface defects in comparison to the clay bar above which removes above surface defects.  However polishing offers no protection and should be followed with a suitable wax or sealant or indeed both!
Types of Polish
Cutting polishes – These contain tiny abrasive particles and actually remove a very fine layer of paint from the surface of a car.  These are also called body scrubs and swirl removers.
Glazes – These are pure polishes and do not actually ‘cut’ the paintwork, instead they nourish and add a deep gloss appearance.
All in ones – These are often what your local Halfords sell and will include a cutting agent, a glaze and a wax all in one.  They are quick and easy to use but do not offer the same level of shine or protection as completing the steps individually.  In addition regular use of these is not recommended due to the cutting action.
How to apply polish
Do not apply in direct sunlight.  Polish can be worked in by hand (foam pad) or by using a random orbital buffer.  There is no need to let it dry but do work it in well.    It can then be wiped off with a soft towel to prevent scratching the paintwork.  Your paint should now be smooth and ready for waxing!
WAXING AND PAINT SEALANTS
After all your hard work so far you will want to protect your finish from the elements.  Waxing or sealing your cars paintwork is a sure fire way of achieving this.
WHICH WAX FOR ME?
There are a vast array of waxes on the market from paint sealants, carnauba waxes and cleaner waxes (all in ones). Waxes also come in paste and liquid form so, which is best for you?
I haven’t stated any wax manufactures below as all manufactures produce a wide range of waxes, however respected manufactures include Mothers, Meguiars, Poorboys, Nattys, Klasse, Zaino and Zymol though this is expensive and similar results can be achieved for a lot less.  Wax products bought from Halfords are generally best avoided.  Given that Autoglym extra gloss is a good paint sealant.
Pure Wax
More often than not these come in paste form in a tin.  They provide your car with a warm gloss look but are not overly durable and require re application every month or so depending upon your cars usage.  These waxes can be very good at hiding (covering) swirl marks in paint
Paint Sealants – (Synthetic waxes)
These are in effect synthetic waxes.  These last longer than the traditional carnauba wax but purists would say do not offer the same level of warmth to your paint that a carnauba wax would.  These often come in a liquid form and are often applied to the car as a whole and left to ‘cure’ before being buffed off.  For a great look ‘top’ your paint sealant with a pure carnauba wax for added shine and protection.
Cleaner Wax
This is a mixture of polish and wax and in effect combines the steps of polishing and waxing.  Often these contain cutting agents and can hide or assist in the removal of swirl marks.  A cleaner wax is useful to save time but will not give you the same results if the steps are done individually.  These are best avoided for regular use but can achieve good results on older undamaged paintwork.
Colour Waxes
These contain synthetic waxes and heaps of colour ‘fillers’ which very effectively hide the swirl marks and scratches on a car.  However the fillers tend to wash out revealing the scratches again.  These are best avoided and any swirl removal should be done in the polishing stage above.
Applying Wax
    * Work in a cool shaded area out of direct sunlight.
    * Use a foam pad to apply the wax.
    * Work on one area at a time.  Some products may allow you to coat the entire car before buffing off, but most do not.
    * Follow the wax manufacturer's instructions on whether or not to allow the wax to dry before buffing.
    * Use a small amount of wax at a time, and rub it in well.
    * If the wax residue does not buff off easily, switch to a clean micro fibre or terry towel.
    * Apply your wax in a back-and-forth motion, not in circles.  If you are creating swirls, you need to replace your applicator or towels.
    * A second coat of wax can be applied typically 24 hours after the first to ensure complete and even coverage.
    * Waxes can also be layered, e.g. applying 3 – 4 coats for maximum protection from the elements.
