Water Coolant Problem?
Car  Renault Clio 1.4
I was driving around in my clio 1.4 RT mk1 earlier today, i opened the bonnet to find my jack when i saw that the container which holds the water coolant was bubbling at the top, not leaking severely but bubbling slightly as if a seam has split.
Should i be worried, any solutions?
they are known as pressurised cooling systems I belive, but they are not really meant to hold any significant pressure. If the filler bottle has split then you can easily easily pick one up from a scrappy for pennys tbh, but I wouldnt worry about it no. Just keep an eye on your coolant level, because a new HeadGasket and or a warped block wont be all that fun.
