water in footwell
Car  clio 172 mk2
clio172 ph1 just noticed big puddle of water in passenger footwell has anyone any idea where that would come from and do drain holes get blocked
I have exactly this problem - water collecting in the passenger footwell (carpet is very damp).
Coolant level seems fine, and door seals look ok. I've purchased a tool to remove the wiper arms - will check the scuttle later.
Yea, had the same problem.
Had to take out all the carpet and the foam and dry everything out, must've taken out about a litre of water.
Turned out it was the centre drain blocked up, under the scuttle panel.
mines the same as this he pass side carpet is soaked! but i also have a wet patch next to the jesus christ handle on the pass side could this be the sunroof?
