Water temp at max + stop light
Evening all,
Went out this evening for a spirited drive, all fine until on the way home the water temp went bananas and was sitting at max until I was able to pull over. Engine stop light came on. I turned it off, opened the bonnet and let it cool off for a bit.
After a few minutes the temp was back to the middle of the gauge and stop light was off. Limped it home, the gauge rose a little (1/2 -1 bar) and back to the middle, it never went below the middle.
Any suggestions of cause or how to check what might be the problem?
cheers Nick
Ey up Mick. When I checked the coolant at the road side it was below min, opened the cap an it boiled up and the level went up/then dropped. Not sure about heaters as they weren't on at the time. Should I check them now?
It'll be too late now. Whenever something goes wrong with the cooling circuit the first thing to go wrong is the heater output.
Sounds like a coolant leak. Any competent garage should be able to tackle this for you but i'd guess at Radiator or water pump leaking myself.
