water temp sensor...
please , someone must know! if the temp gauge doesnt work would this stop my fan from working ? i did the paper clip test on my fan switch and the fan works fine , but doesnt seem to come on when ive driven it ! :confused:
Im not sure if it can stop to work the fan, probably not, coz related to the water bulb, but for sure you can get a new temp sensor.
Adriano
The red thing is a throttle potentiometer which relates throttle position and rate of change to the ECU. Your fan should still work even if the temp sensor is not reading , you can check the fan works by letting the car idle for a while when the radiator gets hot the fan will cut in (if its working) If you gauge goes up to 3/4
Thanx mate,
probably this is the reason of my probs ;-)
Adriano
