weird whistling noise
n2x
  e60/f10
Hi!
I have a problem with my 172 that started couple of months ago. When driving, there is an unbareable whistling or creaking noise coming from the rear end. It seems to apprear when i let the steering wheel loose. If i turn the steering wheel to the left of to the right, the sound dissapears. I have had my brakes checked, rear brake pads replaced and nothing seems to help. Might there be some sort of a problem with power steering or lack of oil somewhere? lol :dead:
Can it be a common problem for a Renault ?
Sry for my English if there are any mistakes.
Cheers from Estonia!
n2x
  e60/f10
I don't think its bearings because the sound is of a very high note. Bearings are lower :/
  Lots of Alfas
I bet its a wheel bearing if its the rear. Have another check where its coming from.
Usually whistling is belt idlers or the clutch thrust bearing.
