Well and truley FCUKED
ok just got my car back... unbalivably the only problem was the ball joint...
which has been replaced
so far....
£45 to tow the car to the garage
£42 1 hours labour
£53 part needed to fit car
my alloy is bent in half but the tyre is still bo selecta so i need 1 new phs2 alloy
and i need 1 new seat my airbag light and service light is on, how do i reset that?
also mt steerin wheel is wonky! is that an easy job
james -
As i said earlier...
Others have explained the mech damage.
As for the airbag stuff.
you will need a replacement chair more the likely.
second hand or new (very expensive), so look at breakers, can get some good deals or on here if someone has changed over to RS leathers etc.
You will need to either replace the airbag computer or have it sent away.
PM bmh.01 , he had his airbag computer done this way without buying an expensive new one.
Costly still tho :(
f**k it, il just trade it in, im past caring... how much u talking
Well depends how you go about it.
Obv replace broken/exploded parts.
So Airbag and pre-tensioner?
Opt 1 - Replace airbag comp, then have it configured by Clip (renault machine)
Opt 2 - Have computer sent off, as per previous reply, PM bmh.01 hes done this before, much cheaper option
Opt 3 - Get someone with a clip machine to diable the airbags (IF ur willing to take the risk)
Opt 4 - Have buckets fitted and not give a toot lol
