I used 2000 grit wet n dry , build the paint up with a cocktail stick so its slightly proud then rub it down so its level , let the wet n dry do the work , no need to apply lots of pressure , then megs scratch X to polish it up afterwards .
Try and keep the area you wet n dry minimal , obviously if the area to sand is only very small i.e. a small stone chip the surrounding area will be sanded as well . Patience is the key word when layering the paint and sanding .I'd leave it a couple of days after touching up before sanding .
