Wet drivers footwell
  Clio Dci
Hi guys.
I have been plagued by a flooded drivers footwell for the last month or so. I found the excellent guide on here about it most likely to be blocked sills or the amount of crud that builds up in the arch liner.
Unfortunatly neither of these worked.
I then removed the scuttle panel below the windscreen and it was flooded. Through rooting around in the recess I found a rubber grommet with a flap in the corner (far left looking from front), I pushed the gromet and the water gushed out.
That i thought was the end of my problem but it turns out there is another drainage grommet in the same cavity but below the wiper motor in the centre of the car.
I hope this helps anyone elso who has been having the same problem. I would have taken some pics but you are working blind by feel so no point.
  AMV8, Mk1 Golf
yup had that problem on mine, same place,
was making up to about 2 inches of water behind my drivers seat after a night of rain.
ended up haiving to throw s**t loads of the sound deadening away tho as it went mouldy
