Wet Sanding Clear
Car  White Sti Hatch
Ive just sprayed a Badge and theres small lumps in the clear i want to get rid off and i know ive to wet sand it with 1200 but thing is do i just go over it with the clear once iv done that or do i have to spray it with some colour again ??
flat it with something smoother if youve got it like p1500 or p2000
if not, then carefully flat it with P1200, then just relaquer it. if you break through the laquer and start rubbing away the paint, then id advise to recolour it too
Have you got anything lighter than 1200?
I wetsanded my panint with 3000 on my side strips then lacquered straight over.
The lacquer coverd the sand marks. Not sure if it would on 1200 though.
Ill give it a go and reclear it if not ill wet sand it all and recolour it....
just wanted some advice before i did anything...
