What amp for the window switches?
Hi,
Just a quick question as I don't have access to my car at the minute and am looking at ordering some things for it. I'm going to be rewiring my window switches to new switches in the centre console. Could somebody please tell me what amp switches I need?
  renault clio 1.4 16v
If you are bypassing the uch relays then u need a switch with a large current capacity, but i you are just re locating them then udomt need huge switches
then you should be able to use fairly small switches, just be careful what you use as the wiring is a bit strange, the passenger side is wired through the driver side, ive made up a pin out diagram but i couldn't replicate the diagram with a 6 poll switch, need a 9 poll or something as there is a cross over... or... can just do what i did and bypass the passenger window driver side switch and run one switch for the driver side and one for the passenger side...
Thanks for the advice. Would you be able to show me the pinout by any chance? Cheers.
