I am looking to build a Clio for motorsport use, but it must be under 1400cc for the class I will be entering. The obvious way is to buy a 1.4 and upgrade certain parts, however another line of thought was to get a 172 Clio and fit it with a 1.4 engine, as the base car would have certain higher spec parts such as brakes etc. This is the reason for the thread to find out the differences between the 1.4 and the 172.
Does the 172 have rear discs?
Does the 172 have higher spec front brakes (my son’s 1.4 has single pot callipers on the front) ?
Are the dampers / springs, stiffer / different spec from the 172 to 1.4 ?
Are the gearboxes the same. Either way what are the ratios for both 172 and 1.4 ?
Are gearboxes interchangeable ?
Are the driveshafts stronger on the 172 ?
If I did go down the 172 route would the car work by fitting a 1.4 ECU and modify the wiring loom ?
With the exception of cosmetics, are there any other significant different parts between the two cars ?
Doug
Doug
