Hello all its the first of hopefully many posts on here. I have recently bought my first 172 its a 53 plate probably not the best example around but will be soon enough. I have replaced the cambelt and next job is the heavy clutch ..... and here is the question i have to you all, what make would you recomend??? Renault or other. I will be replacing the box bearings and syncro while its out (a little noisy in overrun!!) also the sump gasket while the subframe is off.. may as well make a job out of it..
Hope to get sub helpfull advise, thanks in advance.
Neil.
Neil.
