What could be the issue
-Dan-
Hey guys after some advice or tips what else to look for, I had done 1 track day in my clio must have been out a total of 4 hours and while in the pits checking the car over notices the pass rear wheel had some play so tightened the bearing nut, soon as I got home ordered a new 1 and fitted it the next day, that's 2 weeks ago or so, haven't really used the car much maby done 100 miles or so, got in it to go work this morning and soon as I went around a roundabout the noise was back like a rubbing noise but its not the tyre rubbing on the arches,
the noise is still only present when turning right, silent in a straight line and when turning left, I think this because you are loading the wheel more on right hand turns!
is there anything else I can check that would give the systoms?
Many Thanks Dan
Its common for people to miss out the washer behind the bearing and for the bearing to die early as a result of the rear of the 172/182.
If you have more than a couple of turns of thread showing after the nut is done up, then that implies its missing.
Hey guys, yeah I replaced the bearing for a new 1, i refitted the tapered washers the goes between the stub axel and bearing, maby a bad bearing?
Cant thank what else could kill a bearing in 100 miles
Just a quick pic I took during the work I was doing to the car, if you mean what I think by spacer, the things that's sitting on the stub axle in my pixture!
Picture isnt working for me for some reason.
Bad bearing or wasnt tight enough are my only guesses if you fitted it all correctly.
