what do i do and what can happen if
Car  clio 1.4RT
Hi all...i decided to look under the car today...1st time ever!!!!!! i know i shold of done this when i bought it from the auctions but hey ho....
as you may see in the pic the exhaust oxygen sensor is sort of these but is not conected and i carnt seem to see the wire either....what can/should i do about this and what are the conciquenses (spelling) of not doing anything.......??????
Must say the car is a 1998 mk 1 clio 1.4rt...it does not use exsesive fuel and no warning lights up on the dash.
Help PLease.
Yeah its just before the cat so it should be there. Can you see the wiring loom for it anywhere??
it could be that the person that had the car before your fitted a flamer kit to the exhaust to which uses a spark plug like that to ignite the exhaust fumes.
oh i didn't realize it was before the cat. yeh prob pikey job them. plug ur computer in and see if it brings up any errors
LOL! Thats the winner for the pikeyiest blank i've ever seen! If they've done that I wouldn't be surprised if they've killed/took the bulb out of the engine warning light, they're should be a lambda loom around there somewhere.
you'll be able to buy the sensor (they're not cheap, usually) but doubtful with the wiring. can't see one in the 'photo but the wiring could be hiding ontop of the heat shield - need to have a hunt around for it
great...how expensive we talking......is it worth it?
if i didnt sort it all out what are the conciquences??????(spelling)
sorry, wouldn't like to guess - you could have a look on the Euro Car Parts or German Swedish French sites and probably gain an idea from there
well ive got that stupid spark plug out now....(1st pic(
but ive had anothe look and it seems that the lambda sensor for my car is right at the very top of the exhaust near the maniflod (2nd+3rd pic)
i always understood it was near the cat???
It's a flamer kit guys. The previous owner(s) must have fitted it.
You remap or trick the engine to run rich and then ignite the unburnt fuel in the exhaust.
Interesting history ;)
99% sure the truth is, someone has fit a non gen aftermarket downpipe, they often come with different lambda locations, and they have improvised a blank for the bottom.
Doing no harm what so ever, yes its not ideal, but you never see it, does its job so no worry!
Flamer kit? before the cat, that would work, like a handbrake on a canoe.
