What do I need?
Ok I have a tap set to cut thread in holes.
I have a difficult hole to tap with the original tap wrench because it’s too big in the gap that I have.
If I put a bar on the end of the tap and then the wrench on the end of a bar it will make my life much easier
So what I need is some sort of “tap extension”
But when you search for tap extension you get water related items which are no use.
Is there a specific name that I’m missing?
Can anyone help?
Well, don't start with a 2 inch pipe if you've got a m6 tap?. Squish it into a square to fit and tack a bit across the end as a handle.
Lol I hadn’t thought about that tbh.
I was trying to find a way to get my socket extensions to work but too much brain power and thus I gave up.
At least this one is good for a few different tap sizes should I need it in future
