J jamielp Car Clio 172 Cup Feb 1, 2014 #1 gearbox has gone on my 172 cup will any 172-182 gearboxes be straight swap or do i need a 172 cup replacement? thanks
I Imartyn Car 172 Cup Feb 1, 2014 #2 The Cup gearbox has a speedo drive, the standard 172/182 dosen't need it as it uses the ABS system to drive the speedo.
sbridgey ClioSport Club Member Car disco 4, 182, Meglio Feb 1, 2014 #3 Incorrect, an early 172 will use a speedo drive gearbox, 02 plate and earlier.
J jamielp Car Clio 172 Cup Feb 1, 2014 #4 so i need a box with the speedo drive ok cheers for the replys.
mark123 Car 172 race 250 meg mx5 Feb 1, 2014 #5 Also the ph1 box has a longer final drive than the ph2/172 cup one but will fit.
B Bobby. Car Audi A5 Feb 1, 2014 #6 You need either the jc5 129 or jc5 089 the 129 is the box from the 172 cup the 089 is from the PH 172 both these have the speedo drive. all other 172/182's use the jc5 130 and these will fit and work but they don't have the speedo drive so you won't have a speedo.
D Dundeecliors172 Car Clio 172 sport Mar 30, 2024 #7 Does a jr5 123 box from a 2.0 Laguna fit the 172?
