What have you done to your car today ???
  406 V6, Race Buggy
Oops, lad down the road from me did that last week in a Punto - although in his case it buckled all the front edge of the roof as well, was a right mess.
1985michael182
I'm gutted. Looked brand new from the front. Spent ages on the bonnet aswell, cut all the inside out to lighten it spent ages making it perfect and getting the aero catches to fit perfect
  Clio 172 ph2
Aww man that’s a shame fell for you pal. Hopefully u can get it back to it’s former glory[emoji108]
Sent from my iPad using Tapatalk
1985michael182
Yea the aero catches creased the roof.
Back to work to fix it again. Front end looked like brand new which makes it so much worst
Brigsy
  T.Turbo
Had the pleasure of helping to remove a seized fiesta tdci injector today. Only had an hr and basic tools which did not really get it going. Inlet off tomorrow to get heavy duty on it ?
The alarm started beeping constantly so I disconnected the battery. Then after much googling I found a thread on here saying to adjust the height of the boot latch. This would make sense because the door open symbol has been appearing on the dash. Hopefully that has sorted it.
Does anyone know if these holes should have plastic things in them like the other one? Also do they serve a purpose?
Mr Trailer Man
Don't adjust that bit.
It's the metal hook near the bumper that you undo and slide in or out.
1985michael182
They are water drains to let water out of the tail gate
Mbeau
  Clio 172
So.. had a good afternoon.
Fresh painted front bumper and bonnet. Painted all the trims in the bumper.
Polished the headlights n wings.
Fitted a sunstrip ready for first track day.
Left work looking like this...... didn't lock the bonnet catches .....
View attachment 1372710View attachment 1372711
b****cks...........
That is proper rubbish. Gutted for you. The pre bonnet pictures look great. I once had this happen on a RS Turbo I owned. I am sure you will sort it. Still gutting though.
1985michael182
Going into work today to repair the roof and fit the roof scoop before it gets painted. I'll get some pictures later
1985michael182
So today.....
Removed windscreen.
Removed ariel base and panel bonded a patch in.
Used dent bars to push dents out and a punch and light chisel to remove high spots.
Filled the roof.
Fitted cup roof scoop.
Metal filled the hole for ariel.
Mbeau
  Clio 172
Excellent progress. You don't hang about. I am assuming you work in a body shop, which is pretty handy!
  997, e208, I.D. Buzz
New front discs, pads, wear sensors & retaining pins, front drop links.
Tomorrow will be air con condensers & water pump... If I can be arsed to tackle *that* 10mm bolt on the water pump.
  406 V6, Race Buggy
Happens more often than you think with pins, I bet every race weekend there's a bonnet or two goes up from missing or loose pins. Mind in our sport that usually just means they jump on the bonnet until a pin goes in, kick the window out and put some goggles on.
  Monaco 172
I decided on Saturday to do my front and rear, discs and pads and uprated evol style dog bone..
3.5 hours later all I got done was the front discs and pads and the dogbone thanks to one of the NS sliders welding itself in the carrier. Luckily it happened at work so one of the techs drilled the slider out and I replaced it with one i removed from a Scenic at a local scrappy, worked very well!! and the brakes are spot on.
The dogbone next, got that changed that in under 5mins and i'm really happy with the difference it's made, not sure why they get the hate to be honest i'm a 36 year old man and I don't think the vibrations or anything aren't that bad.
So if anyone reading this has a pair of front ph2 172 caliper carriers in good condition (figured i'd replace both and fit new sliders) close to Portsmouth, give me a shout ?
  BMW 320d SE
The bonnet on my titanium silver 182 was rusting badly, so I found one on eBay but couldn’t find the right colour. In the end, I had to settle for a white one. I fitted it and although it wasn’t a terrible as I’d imagined, I couldn’t leave it like that. Anyway, it’s been in today to get wrapped in Avery Dennison Carbon Fiber black.
