What injectors fit 172's?
Car  Clio 172
Can anyone tell me if any other renaults share the same injectors as a ph1 172?.
I have a missfire on cylinder 4 and i believe its the injector at fault as the plugs are fine and new leads fitted in the summer and there's loads of spark from the coilpack when i remove the lead but there's no change when i remove the injector lead.
There's a good scrappy near me so was going to try another injector before committing to buying a new one.
Anyone know?
I think that the ones from a Laguna 2.0 will fit the clio as well, unless your scrappy actually has a clio 172/182 down there...
The scrappy option was to check if it was the injectors and also for a spare should it happen again. But it's definitly an injector fault so a new one will be ordered and the old ones cleaned and flow checked.
