what is the actual 172 wheels offset...?
Car  Italian 3.2 V6
i do not know!? and could do with knowing.
is the better the offset the better the ride/handling?
46.8 i think for the standard wheels,
you can go as far as about 37 without too much trouble if the car is lowered.
^^et46, sure thats 182?
Most ideal offset to use from experience is et38, ie Cup offsets.
Well worth upgrading to 10mm spacers on the fronts (5mm per side) if your running a 172 on stock rims imo
was meaning for a 172, but was still a bit wrong:o
well my car is lowered 30mm, will b putting 16/15" wheels on that will be 7" wide, maby put spacers on to fill up arches. Does this help to narrow down to what offset I need?
Those were ET37 so brought the track out 20mm or so, filled the arches perfectly imo barring it being a bit too high.
