What makes an exhaust POP>?
  850 T5. mmmm Turbo!
and why wont mine do it?
i have a decat, and almost straight through pipe. im assuming it must be either the way the baffel works or the design of the pipe??
You'l need a remap, RSTuner would be a good idea as you could request henk to tailor you a map for it to fuel on deaccelaration/overrun whatever you want to call it.
Coby.
  XC60-R.......V40-R
Cos it Sounds Braaap ..... Mine Pop's Loads and loud when Cold and also does the Occasional Burble and Pop when coming down the Rev Range..... I like it :D
Coby.
  XC60-R.......V40-R
I have no idea why mine does it ..... I'm not worried that it does and I wouldn't be going out of my way to get it to if it didn't TBH
  LY 182
you dont want it overfueling at all.
you actually want the fuel shut off on overun, and alter the ignition timing on overun.
throwing fuel down it does nothing but cool the egt's and the exhaust is nowhere near hot enough to begin with to ignite fuel.
  Astra van,Mk1 nova
my old valver with decat and magnex system used to spit maaaooosive blue flames:cool: and wasnt overfueled ;) wish my cup done the same
  ITB'd MK1
correct :)
  ValverInBits
as said, exhuasts pop due to unburnt fuel in the exhaust. You need to be running rich or have a map which fuels on run down.
Try the tesco 100ron, that might pop a bit
Coby.
  XC60-R.......V40-R
Higher RON Fuels definitely increase the Popping though, I've now been through quite a few tanks of V-Power and now got Dirty Tesco 99 stuff in my car and it has defintely been popping more than when run on Basic Unleaded
  340i
Why does everybody think its unburn fuel "popping" in the exhaust system...
Its acutally unburnt air ;) i.e. your car running lean
  ValverInBits
maybe it is in your 4-1 172 manifold.
Things happen differently when you actually fit your 182 manifold.......
:rasp:
:quiet:
unburnt air doesnt burn by itself though.
Lean mixtures burn slower, so on overrun the mixture is still burning as the ex valve opens.
However this is rare on modern cars which just buzz with overrun as they run a total fuel cut off on overrun.
  clio 200 F4Rt
mine pops and bangs like a mofo. 172, Ktec stealth, 182 manifold, de-cat.... oh and bodies, cams, pistons etc etc.
Goes off like a shot gun on full throttle gear changes too!
  A4 oil burner !!!
Think i have just seen your white clio up at GDI this morning !
Was having my sports cat sorted.
Went out for a drive after work last night around 11.30pm and it felt awesome alot more ear friendly then a decat. Defo get some good pops and burbles on overrun now !
