What offset will fit williams....
Car  20VT Clio & 9-5 HOT
Will 35 offset fit my 16v with williams wide track? also what pcd willI need! last question, does anyone know the size of the bore in the middle of the wheel so that it fits on the hub?
the willy wheels iv got on now are close to the arch!
cheers
Center bore is 60.1mm
PCD 4 * 100 is what you need.
I canot remember what stock wheels I think there 42 in which carse 35 offset will be closer inwards by 7mm each side (assuming tyres the same width).
OE offset is 36
my valver with turbines, and willy wide track, is close to the arches, occasionally it does scrub full lock but thats partly due to the front tyres which are cheap and shaped like balloons, it will be fine i think when i put Michelins on
if you change the offset though why bother having the wide track
cheers!
just wasnt sure like, and someone has some wheels i really want, but unlikely they will fit!
Nope!
The higher the offset the further the wheel sticks out, so fitting 35s will give you 1mm less clearance than standard and i used to catch the arch the arches on full lock when it was lowered on standard wheels.
Mat.
its lowered on lowest coilover settings on front with willy track!
centre bore on these particular wheels is too small anyways so they aint gonna fit boooo!!
cheers tho!
If you have the Williams setup you can tell the difference between the correct wheels and the wrong offset wheels I know it sounds unbelivable but that few MM difference can be noticed.
Nope!
Mat.
no, your wrong mate, the higher the offset the further the wheels is IN
Nope!
Mat.
Yeah, lol.
Thats what i actually meant, my statement agrees with Edde!
Mat.
