My oil needs topping up and just wanted to know the exact grade and make of oil that renault use in the Cup please?
The stuff thats in there now is Elf 10W40 semi-synthetic oil rated to ACEA A3 standard and you wanna top it up an oil that conforms to that spec, dont start mixing oils of a different viscosity!Quote: Originally posted by clio sport on 07 October 2003
It doesnt "have" to be the Elf stuff, you can top it up with a different make, but you need to keep to the original spec, so 10W40 semi-synth is the stuff and check its ACEA A3 rated, will be on the back of the bottle!Quote: Originally posted by jon_r on 08 October 2003
As rich says use the Elf stuff!
